Another Alltrack owner with leaking sunroof experience.  Thought i'd comment here to bolster the discussion.
Trip #1 to the dealer after finding water leaking into the rear lift door and coming out when it was opened. They traced it to the sunroof and replaced the frame and headliner. I had to go back to the dealer after I noticed some small snaps and other details weren't put back correctly.
Trip #2 to the dealer after finding water stains on the replaced headliner. This is when I was told that it was due to the drain plug issue others have talked about. The plugs were ground down to prevent clogging. A second headliner was installed as well as the entire carpet (They found water at the driver and passenger side floors. I had to return this time as well after areas of the headliner were not finished properly.
Honestly, I'm kind of hoping for the issue to happen again so I can pursue the lemon law in MA. I was driving on the highway today at 70mph and the car's alarm system went off. I tried to figure out what was happening, if I pressed some weird distress button or something, merged to the right and pulled over. By then it went off as if nothing had happened. I'm worried that the car's electrical system may have been affected by the water intrusion. Any thoughts there?
				![Mad    [mad] [mad]](/images/smilies/mad.png)
