First recall 2017 Alltrack
steel1
Got a recall a couple of days ago regarding a transmission limit switch.
Sounds like switch could get corroded contacts causing the vehicle to not recognize it's in the park position (possible roll-away).
Not sure if this only includes states that see snow but no fix available yet so use your E-brakes !
Thanks for the info. Going to check with my advisor when I bring it in for service next month.
I checked the NHTSA website and it doesn't show up there on our 2019 SE model.
steel1
Had to bring my 2017 Alltrack in for a leaking thermostat housing, they also took care of
the limit switch recall while they had it.
Yep 33k miles and was leaking coolant, little frustrating to say the least.
