You mean wheels right? (Sorry to nitpick) Your SEL should have just regular 17mm lug bolts on each wheel unless dealer installed wheel locks. Pull off black plastic caps off one wheel to expose lug nuts and see for yourself. You should have little hook tool in your tool kit that came with the car that's used to pull off those caps.
Now if you're asking can you purchase them (keyed wheel bolts) the answer if yes. https://parts.vw.com/p/Volkswagen__Alltrack/Lockable-Wheel-Bolt-Set/49463569/000071597.html
Pretty nice as they come with their own plastic caps which are different that the caps for the 17mm bolts. Note these are made for Stock VW wheels and are proper length and "ball seat" style or you have aftermarket wheels that use Stock VW wheel bolts.
