Leaking moonroof poll, what year is your Alltrack?
  • 2017
    Votes: 12 75.0%
  • 2018
    Votes: 4 25.0%
  • Total voters
    16
oreozzy
Mine was built in late 2016, but the 2017 model. The dealer tells me it's a leaking sunroof, though I'm not positive it is (haven't seen any water leaking around the roof, only in the spare wheel area)
AL
Mine was a 17 never leaked just had too many other issues with it so I traded it on on a 18 R.
2017. Bought new in 6/2018 in Bakersfield, CA. Didn’t leak until November of 2019. Then it was a freaking waterfall. Ancira VW here in San Antonio was awesome and went to bat to set it straight. Performed the drain tube repair/modification, replaced the headliner, and offered to replace any electronics that may have been affected by the moisture, with no expiration on the offer. Also provided me with a loaner while the headliner was being replaced (about two business days, but there was a weekend between). In the end, I couldn’t have been more comfortable with what could have been a majorly stressful process.
This showed up in my mailbox the other day...
NDB
#10
Same here '17, Luckly mine doesn't leak although I'm aware of the issue and park under covered parking at work and garage at home although the first 2 years I didn't park in garage and it rains a lot here in Washington. One issue though is during the summer running A/C and at night when it's cooler and A/C is off, if I don't have fan turned up and blowing mainly tru defrost (W/warm air) sometimes my windshield will fog up which is very annoying (not anything like a leaking S/R though) . I got 'service bulletin" about S/R drains recently and having that (fix) right now , I was told by service rep they cut drain hose at angle which supposedly helps prevent blockages? We'll see. Either I'm lucky or it's just a matter of time. This is a major issue though and VW should have #1. designed a better roof/drain system #2. Stop denying owners with this issue, and man up to their faults. Stuff like this (and diesel gate, and carbon build-up on valves, and, sound system disconnect issues and,and,and) have made me lose faith in this company.
Sad thing because I've exclusively owned either VW's or Audi's since 1975 and you'd have thought the sunroof issue would have been solved in this day and age.
SAN RAFAEL
2017 VW All Track
#11
2017..Had it fixed once in 2018 and now it's gone again. Dealership says it's out of warranty. Off the record told me to contact VW and ask them to pay for it. Is this an insurance claim or should I push VW HQ to fix this? This is really annoying. I didn't realize it had been leaking but did notice a terrible smell. Looked at the spare tire hub and it was full of water. So the drains haven't been draining properly.
Greenwich
CT
2017 Golf Alltrack
#12
I have a 2017. It was repaired during the recall once. But continues to leak and now the electric is showing signs of being fried - the audio system goes on and off, the radio won't turn off when the car turns off.
Boston
MA
2017 Golf Alltrack
#13
I have a 2017 Golf Alltrack. The other day I found substantial pools of water on both sides of the rear floor. No water anywhere else. Not rear cargo, not in front floor and no signs of wet or water staining on side pillars or anywhere around interior roof. It is as if someone poured a pint or two of water directly on the rear floor, both passenger and drivers side. Also, no sign of dampness around bottom of doors or seat... only water was directly in the floor where mats sit. I did have an issue back in 2017 with leaking water into drivers foot area but that was fixed by VW and no issue since. That was obvious because there was water staining on roof and front pillar. I was out of country for 2 weeks and we did have a few good rains but I've never had this before. Only other thing is I went to a car wash before I left and had an undercarriage wash. But I have done this many times as well. Very curious as to where it came from.
#15
There are other places that leak besides sunroof, you'll have to research I have and there's about 5 areas where water leaks in other than sunroof.
One area is the door drains which sounds like your issue. As I said you'll have to research on YouTube I know I saw a fix for it. But IIRC it's one of the more involved fixes requiring removal of door panels.
Other areas (not for your issue) back-up camera drain grommet breaks off allowing water to enter cargo area check if grommet is still intact if it's missing and just a hole then you'll have to replace entire hose (there's a video on YouTube showing how) requiring removal of interior plastic panels on hatch to get to drain hose (entire hose has to be replaced grommet is bonded to hose)
Another common area...The rear quarter panel vents a large louvered flap system, the frame is the culprit it allows water to leak into cubby hole storage area on either side of hatch. Removal of rear bumper cover to gain access, fix is remove entire frame clean and reinstall using sealant around loose fitting frame. Be sure to remove rubber plug to drain standing water then re-install plug.
Another area at top of rear hatch rubber grommet for electrics inside hatch leaking water inside hatch...seal grommet
Another area tail light seals can leak, over time these seals can leak remove tail lights thoroughly clean all mating surfaces re-install if leaking persists I won't recommend anything here as I don't want to give bad advise...but I have seen people use sealant which I wouldn't recommend because it will make future removal very difficult.
I think that about covers it at least that's what I recall...everyone that's concerned about leaks should check these known areas.
Boston
MA
2017 Golf Alltrack
#16
After much investigation, I have found the following;
No sign of water at all on headliner, side pillars, cargo area etc. I concluded that the water MUST have come from the floor only. Since it was only in the rear floor area, I ruled out any leaks from drivers area and forward. My cabin filter was also dry. The fact that the ac/heat vents to rear seats come under front seats and point directly at floor, I was confident the water came from there. Also, no sign of water under car after running ac and my dash control airbag sensor lit up. The sensor is under the front seat. Conclusion..... evaporator drain must be clogged and backing up into rear console vent. Going into dealer on Monday. Will see what they find out.
#17
Jack Track...You mentioned having undercarriage washed, I wonder if there are plastic/rubber plugs under there that could possibly have come loose or gone completely, I don't know if there are plugs like that on these cars but I know my Mk4 had them. You also mentioned the rear vents for heat/ac might be the culprit...I don't know how that would be possible. If the drip tray for A/C is overflowing (plugged drain) I would think the front floor would be soaked not the rear. Did you research leaking door panels that sounds like the more likely place...good luck I hope you get it resolved before fall/winter.
C Maintenance, Warranty Issues & Troubleshooting 110
