Lifting an Alltrack
crashton
I've never seen that. It seems like a rather simplistic & not very elegant way to add ground clearance. Too many compromises there. I'm looking for a gravel road capable car that is why the Golf Alltrack interests me. If I wanted mongo ground clearance I'd be looking at the Subaru Crosstrek.
My main concern would be the resultant increase in drive shaft angles which would result in compromised longevity of the CV joints and boots. VW would most likely drop you like a hot potato if you had CV failure with these fitted.
You may be safe with 12mm spacers, but 48mm? That sounds extreme.....
bigdecals
bigdecals
Thread Starter #6
Winchy, the dealer near me did raise a 17 model. They sold it as brand new with taller tires as well. I've been trying for a month to tell me which kit they used but no one at the dealership is saying anything. That's probably why!
Sent from my iPad using Tapatalk
bigdecals
bigdecals
Thread Starter #7
Thanks for the heads up [MENTION=45]bigdecals[/MENTION]. Surprising to say the least!
I wonder if it's factory backed or just a dealer pimped unit?
Keep us updated on your findings[emoji106]
bigdecals
bigdecals
Thread Starter #10
Dealer Pimped from Hudson Valley VW in Wappingers Falls, NY
Le duke
I wish adding a 1? lift to these cars was as easy and cheap as doing it to my old Subaru.
Plenty of companies out there selling HDPE spacers that went between the strut ?top hat? and the frame. Hell, you can make your own for $30.
Is there no reasonably priced after market solution for VWs?
Comstock Park
MI
17 Alltrack S
#16
Check out B2BFab for a safe lift kit. I just got mine installed a while back and love it. 1.5" lift/level, with Atlas rear shocks (to regain the lost travel and beef up the rear for towing or extra caego), and 215/65R16 General Grabbers. APR Stg 1 ECU and TCU tunes help liven it up.
Also, Smith VW is nearby B2BFab, in Delaware, and they partner and help modify similar rigs.
Reid
Bend
OR
2017 Golf Alltrack TSI SEL
#17
Did you get the complete lift kit from b2bfab or just the basic one? I’m looking at getting a lift on my 2017 Alltrack and I’m leaning towards going with the b2bfab lift kit but not sure if I needed the complete one for ~$1200 or the basic one for ~$700
