Minor program modification
Gray Bark
2019 Golf Sportwageen
The "lane changing" function of the turn signal requires one touch to flash the turn signal three times. I change lanes more slowly than that, and I'd like the signal to flash four times (at least). Can this feature be re-programmed?
2019 AT SE 6MT
Comfort turn signal can be upped. IIRC 5 is common change.
You'll need a vcds hex-v2 to make the changes. https://store.ross-tech.com/shop/vchv2_ent/
Or google for a vag-com locator list, but these are usually consumer locked to a limited number of cars (vins).
Good luck!
