Coil packs not coming out
Dallas
2015 Audi S3
Anyone have any suggestions on removing my coil packs for a spark plug change? Only one of them came out like nothing? currently at 65k miles
ViperG
Moderator
Philedelphia
PA
2016 Viper Green S3
Pull hard try it hot try it cold. I had the same thing on my mini the last change boy were they hard to pop off. I was ready to try to get some wood and try to pry them but the valve cover is plastic so didn't want to crack it. It really took a lot of force.
C
Dallas
2015 Audi S3
Yea from what i saw online i’m just going to have 2 rip em off so i got these as replacements since they’ll probably rip
Moderator
socal.
2015 s3
the method im mentioning is basically going to damage the bottom section of the coil pack. its rare youll be able to save the boot section.
the coil packs are a 2 piece unit. the bottom long stem rubber section and the square top.
remove the top. they come of with some persuasion. its like a boot. once off you take out the inner spring.
add in some wd40 and let sit for a few mins. work on the next.
go back at the end of the row.
use a long skinny pick with a small blunt tip.
push down the hole with wd40 oil.
go up and down, all around the spark plug on the inside of the boot.
after a nice go around youll be able to pull up the boot.
the boot can be damaged as you should be able to buy a new set but keep the top coil pack to reuse.
